I just got a new PC & loaded it with Audacity 2.0.3, but I'm having difficulty getting the program to record the "speaker audio" (I use this quite a bit for recording podcasts, et al). In the past (with other PC's), accomplishing this seemed to happen almost by default, but now (in spite of a lot of trial & error settings adjustments) I can't seem to get it to pass though. I might also mention that this is my first Window 7 computer (just in case that might have something to do with it). Any help would be appreciated.
Brian
'Recording speaker audio' question...
pbkshortwave
- Quality Assurance
Re: 'Recording speaker audio' question...
