Need help getting started
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
hoakieman
Post by hoakieman » Wed Feb 27, 2013 7:18 pm
Hi All, I am new to Audacity and am not the most technically inspired. I want to record myself reading from a book onto my laptop, using WIN XP, I could not find anywhere in the instructions as to if Audacity records onto the computer hard drive or onto my CD drive and how to control the recording if I need to stop and come back to it later. I would appreciate some basic help in getting started.
I really like the idea of using Audacity and am not computer illiterate, but I am Older and a lot of my brain cells have retired even though I have not. Thanks for any help and advice, I amusing an older Dell Inspiron E1705 laptop with a RW CD and DVD player.
Hoakieman
waxcylinder
Re: Need help getting started
Post by waxcylinder » Wed Feb 27, 2013 8:13 pm
A good place to start is the set of Tutorials in the Audacity Manual - they should help you get started- see: http://manual.audacityteam.org/o/man/tutorials.html
Although this set is primarily aimed at LP/tape conversion much of it will apply to your needs: http://manual.audacityteam.org/o/man/tu ... to_cd.html
hoakieman
Post by hoakieman » Wed Feb 27, 2013 8:44 pm
OK, That helped, I needed to know if Audacity would record directly from the microphone to the CD or if it made its own file. Now I know what to do. I looked for it in the manual myself, but did not find it, thanks for the link. It took me right where i needed to go.
waxcylinder
Post by waxcylinder » Wed Feb 27, 2013 11:20 pm
glad to be of help :)
We've actually restructured the manual slightly (for the next version of Audacity) to make those tutorials that you needed a bit more visible and discoverable on the front page.
Would this (slightly) revised front page have led you in the right direction: http://manual.audacityteam.org/man/Main_Page ?
Trebor
Post by Trebor » Fri Mar 29, 2013 12:01 am
hoakieman wrote: I could not find anywhere in the instructions as to if Audacity records onto the computer hard drive or onto my CD drive ...
Audacity doesn't write (aka "burn") data onto a CD / DVD , you'll need other software to do that ... http://manual.audacityteam.org/o/man/bu ... _a_cd.html
