How to increase FFT resolution?
This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the Adding Feature forum.
Technical support is available via the Help forum.
fonon
Post by fonon » Tue Feb 26, 2013 10:42 am
I'm new Audacity user. The current limit of FFT window size is 2^14 samples. Is it possible to extend it up to 2^16 samples? How?
Regards,
f.
Re: How to increase FFT resolution?
Post by kozikowski » Tue Feb 26, 2013 11:13 am
Audacity > Preferences > Spectrograms > FFT Window.
That's the only setting I know of.
fonon
Post by fonon » Tue Feb 26, 2013 2:13 pm
kozikowski wrote:Audacity > Preferences > Spectrograms > FFT Window.
As I wrote, the fft window size is limited up to 2^14 samples. I need larger window - 2^14 samples.
f.
Post by steve » Tue Feb 26, 2013 5:26 pm
Which FFT window size are you asking about?
Plot Spectrum? Wave track spectrogram view? The Equalization effect? Somewhere else?
fonon
Post by fonon » Tue Feb 26, 2013 8:05 pm
steve wrote:Which FFT window size are you asking about?
It's only one "FFT window size" - the number of samples used to calculate the spectrum. The FFT window size determines the frequency resolution of analysis (at specific sample rate).
f.
Post by steve » Tue Feb 26, 2013 9:43 pm
In the current Audacity 2.0.3 the FFT size in "Edit > Preference > Spectrograms" goes up to a maximum of 2^15 (32768). The developers decided that going higher than this is just too slow.
Audacity 2.0.3 is available here: http://audacityteam.org/download/
fonon
Post by fonon » Tue Feb 26, 2013 10:30 pm
steve wrote:In the current Audacity 2.0.3 the FFT size in "Edit > Preference > Spectrograms" goes up to a maximum of 2^15 (32768). The developers decided that going higher than this is just too slow.
The window size of 2^16 must be slower then 2^15. It can't be too slow for these who need it. The user who need faster analysis can select shorter window. The number of 2^16 samples is a rational limit of window size. Adobe Audition has this feature.
steve wrote:Audacity 2.0.3 is available here: http://audacityteam.org/download/
Unfortunately rpm file isn't available yet.
f.
Post by steve » Tue Feb 26, 2013 10:43 pm
fonon wrote:Unfortunately rpm file isn't available yet.
Well if you're on Linux, why not build Audacity 2.0.3 from the source code (or even get the latest svn version, which is very stable at the time of writing), then you could enable FFT size up to 2^16 if that's what you want. The change is just to add:
Code: Select all
   mSizeChoices.Add(_("65536 - OTT"));
after line 53 in SpectrumPrefs.cpp
fonon
Post by fonon » Thu Feb 28, 2013 8:50 am
Thank you for suggestion. I will try. Unfortunately, I need both - windows and linux versions. Since there is no problem with increase the FFT resolution - the developers will do it.
f.
fonon
Post by fonon » Fri Mar 01, 2013 3:25 pm
The "Size" parameter in "Analyze/Plot Spectrum" is still restricted to 2^14 samples (Windows version). Could you explain what it means and why the ranges of "window size" in "Preference/Spectrograms" and "size" in "Analyze/Plot Spectrum" are different?
f.
