Muted audio from track 1 shows up while recording track 2
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
copie719
Post by copie719 » Wed Feb 20, 2013 4:16 pm
Recorded drums as our first track and attempted to record guitar on a 2nd. When you hit record you can see the audio profile from the first track while recording the second. Please help to figure out what the issue is.
Re: Muted audio from track 1 shows up while recording track
Post by steve » Wed Feb 20, 2013 4:52 pm
What's the problem with being able to "see" the waveform? Do you also "hear" the waveform? Or do you mean that you can see the waveform from the muted track appearing in the new track? We can't see your set-up so you will need to describe in complete detail what you are using, what you are doing and what is happening.
copie719
Post by copie719 » Wed Feb 20, 2013 5:03 pm
You see the waveform from the first track in the new track. And it also distorts the first track by make a "swirling" sound effect on track one overall. We have used Audacity before and this is the first time we have seen this happen.
Post by steve » Wed Feb 20, 2013 5:07 pm
copie719 wrote:And it also distorts the first track by make a "swirling" sound effect on track one overall.
How can you tell there is a "swirling sound effect" on track one? You said that track 1 is muted :? Is the mute button pressed on the track panel on the left end of the track?
copie719
Post by copie719 » Wed Feb 20, 2013 5:10 pm
Confusing I know, sorry, but even with track 1 muted you can still hear track 1. doesn't make sense to us either.
Post by steve » Wed Feb 20, 2013 5:14 pm
You will need to describe your set-up in fine detail.
If an audio track in Audacity is muted, it does not play.
copie719
Post by copie719 » Wed Feb 20, 2013 6:17 pm
Well we have an older Yamaha soundboard that we connect to the computer via RCA chord. Then we plug headphones in to the audio out so we can hear track 1 while recording additional tracks. Pretty simple, or so we thought. It seemed to work before so we are trying to figure out what changed.
Post by steve » Wed Feb 20, 2013 6:48 pm
It sounds like you have a signal routing problem with either the mixer or the wiring. Probably time to dig out the Yamaha manual.
You can mute a track in Audacity so that it does not play by clicking the track mute button: http://manual.audacityteam.org/o/man/au ... .html#mute
copie719
Post by copie719 » Wed Feb 20, 2013 7:10 pm
Ok, thanks. Will attack it again and see what happens. Thanks!
copie719
Post by copie719 » Fri Feb 22, 2013 8:17 pm
Looks like it has to do with my sound card. When you try to record a second track it copies the first track, even when you mute it. You can't hear it if it is muted, but it copies it. I tried another computer and it records the second track fine. Any ideas?
