Adjusting Volumes
guitarist321
Adjusting Volumes
Post by guitarist321 » Tue Feb 19, 2013 6:41 am
I have 5 songs which I did fade ins and outs as a mix, on 1 stereo track, and some songs are louder or lower than the others. What is the best tool to use to even out the volumes?
One song in particular is quite a bit louder than the others...anyway to highlight that segment to lower the volume, or will a tool do it for all song levels?
thx!
Re: Adjusting Volumes
Post by steve » Tue Feb 19, 2013 7:36 am
guitarist321 wrote:I have 5 songs which I did fade ins and outs as a mix, on 1 stereo track, and some songs are louder or lower than the others. What is the best tool to use to even out the volumes?
Probably the Envelope Tool http://manual.audacityteam.org/o/man/envelope_tool.html
