I'm using a little consumer-grade Sennheiser PC 8 headset on Mac 10.6.8 and every recording I take has a light (but audible) mosquito hum. I don't hear any hum as I'm recording, but the resulting audio files always have the hum.
I've been using Audacity 2.0.3 (dmg) to remove it, but of course it can't remove it perfectly, and it's an annoying step. I've been adding cheesy background music to my screencasts just to distract people from the noise.
I know the problem is the headset. The hum only affects recordings made with this particular headset, not regular internal mic recordings. The hum happens on different computers located in different rooms (no speakers or humming electronics nearby), and it doesn't matter what program I use to record the audio - Screenflow, Wiretap Studio, whatever: if I use the headset, I get the hum. But this headset is just two weeks old so I'm wondering if there's something obvious I'm doing wrong that will avoid me having to buy another, because I can't find the warranty...
Sample attached. If you turn the volume up you can hear it better. Would be grateful for any ideas! I am a total beginner.
