Test Microphones with Audacity?
KenO
Post by KenO » Fri Feb 15, 2013 4:40 pm
Am in the market for a neutral sounding omni microphone for use in both studio and on location recording.
A friend loaned me his AKG "Mic Check Microphone Comparison CD". http://mixonline.com/news/audio_akg_mic_check/ Since the headphones or speakers used in playback may significantly affect the evaluation http://transom.org/?p=7517 , I wonder if there is a way to use Audacity for this purpose (am esp interested in freq response, and S/N).
Did a forum search using Keywords "test" & "microphones" but found nothing similar to this question.
Then decided to check Tips and Tutorials, and found a lot of interesting material but again nothing similar to this question.
If Audacity can not be used to test/evaluate mics, would be interested in any software that others have found useful for this purpose.
Thanks
Ken
Re: Test Microphones with Audacity?
Post by kozikowski » Fri Feb 15, 2013 6:39 pm
You probably shouldn't be. Omnidirectional microphones appear to be wonderful creatures until you try to use them. In almost all but carefully controlled studio conditions, they're almost useless. Almost useless because if your task is to record natural sounds like outdoor environment birdcalls or stuff like that, they're perfect. If you're not a bird, leave that mic a home.
Have you heard or do you know of the radio show 'This American Life?' It features live, non-studio, unscripted interviews with hundreds of people every week, and they all seem to work perfectly. This is impossible, so I looked into it. Not only do they use a directional microphone, they use a very highly directional shotgun microphone and they get it as close as possible to the person talking -- usually inches away.
For one example:
http://www.zzounds.com/item--AUTATR6550
I can almost quote you all the part numbers of the omni-directional microphones on the market -- there aren't that many -- but there are millions of cardioid, super-cardioid, hyper-cardioid and other directional microphones on the market because for almost every recording situation, they are appropriate.
The two directional microphones you are familiar with even if you don't know it are the Shure SM58 and Shure SM57.
The SM58 is the Rock Band Microphone.
http://www.shure.com/americas/products/ ... microphone
The SM57 is the drum set microphone. Both microphones were introduced in the dawn of recorded history and are still big sellers. They're both very directional.
Microphones are not noisy. The signal from a moving coil (Dynamic) microphone has molecular-level noise -- effectively zero. The mic preamp, soundcard, or mixer however are insanely noisy and it's the dance between them that determines how hissy your performance is.
None of these microphones are flat (See illustration).
They are sometimes intentionally lumpy and the lumps change with frequency. The true test of a microphone is not what happens in front which is obvious, but what happens in back. How well does the rear cancellation work.
So while it's a terrific idea to want a good, all-around microphone, the quest is not likely to be successful until you define everything else around the system and in particular, the jobs you will be doing regularly.
If you have a "standard" microphone, you can do a quick and dirty test with a newspaper. Pick a reasonably quiet room and crumple up a newspaper around six feet (2M) in front of the microphone and record it in Audacity. This assumes everything else in your pathway is clean and well behaved. Compare the different microphone crumples with the Audacity analysis tools. In one swoop, that takes the speakers, cables amplifiers, and other playback equipment and software out of the equation.
The problems go on. Studio microphones get killed with wind noise. Field microphones tend to sound tight and restricted because of their need to cancel the environment.
Omnidirectional microphones tend to produce work like this. You can't fix that in filters or effects and you can't get rid of the room echoes with that kind of microphone.
http://kozco.com/tech/audacity/clips/EchoSample.mp3
Screen shot 2013-02-15 at 10.19.16 AM.png (8.54 KiB) Viewed 1472 times
KenO
Post by KenO » Fri Feb 15, 2013 7:29 pm
Koz,
Thanks for your detailed explanation for not getting an omni mic.
How do you evaluate mics?
Thanks again for your help.
Ken
DVDdoug
Forum Crew
Post by DVDdoug » Fri Feb 15, 2013 7:40 pm
Of course... But the idea is to compare the relative sound of one mic to the others. It's probably best if you choose one or two of the best (or more expensive mics) as the reference and compare the others to the reference top get a feel for the diffrence, rather than trying to judge the overall sound of each mic. It's just too bad it's only the mics from one manufacturer.
The main difference in the way mics "sound" is the frequency response, and if you don't have the perfect mic for every situation, you can do a LOT with equalization. I suppose it's nice if you have a pro studio and you can have a "mic locker" with just the right mic for every occasion. But for home recording, you can usually get-by with one or two good mics and EQ.
Directional large diaphragm condenser mics are used for almost everything in "the studio". The Shure SM57 (same as an SM58 without the ball-screen) is probably the only dynamic (non-condenser) commonly used in pro studios. It's often used in front of a guitar amp, or to mic a snare. But for home recording, an SM57/58 is not a terrible choice. After all, it is the most popular mic of all time!
Condenser mics tend to have better high-frequency response than dynamic mics. i.e. They tend to be "brighter" or have more "sparkle". Small-diaphragm condensers tend to be "brighter" than large-diaphragm condensers, so they are often used as drum overheads to pick-up the cymbals.
You can also get condenser mics with patterns switches (cardioid, omni, figure-8), pad switches (to knock-down loud sounds), and sometimes filter-switches to roll-off the low or high end. It's usually the electronics in a condenser that gets overloaded with loud sounds, so this isn't such a big problem with dynamic mics. i.e. The SM57/58 doesn't have a pad, but it's is almost impossible to overload.
Flat, ommnidirectional, instrumentation microphones have the "best specs", but they are rarely used for studio recording.
If you are getting a strong signal into the mic (such as a singer with a strong voice, within a few inches of the mic), acoustic room noise if is often the major noise source, even in "soundproof" studios. And, condenser mics do have electronics that contribute some noise.
...and on location recording.
As Koz says, this is very tricky. Virtually all on-location movie dialog is re-recorded in the studio, and all sound effects are also re-created in the studio. When that's not possible (such as live newscasts) they just have to get the mic as close as possible to increase the signal part of the S/N ratio, and some noise usually gets through... Sometimes the noise is not too noticeable (the viewer/listener expects some background-environmental noise), and sometimes it's terrible and distracting (such bad wind noise, a barking dog, or a loud siren).
P.S.
Probably any AKG mic will be acceptable for most applications.... Or just about any "studio condenser" that costs around $100 USD or more. Just avoid "computer gaming" mics, or other super cheap mics and you should be OK.
I'd guess the "sweet spot" is around $300. Above that you might not get "better" sound" or you might have to pay a lot more to get slightly better sound... Although, just about every mic sounds different, so you might like the sound of a more expensive mic, or a less expensive mic. A good mic with switches, or other "features", and a shock mount could run twice as much.
Post by kozikowski » Fri Feb 15, 2013 8:35 pm
That's pushing it. Studio re-recording takes time and time is very expensive. Much better to get it the first time.
http://kozco.com/tech/audacity/pix/Boom.jpg
http://kozco.com/tech/audacity/pix/BarbecueShotgun.jpg
For years we didn't have women boom operators because they were judged not strong enough. Then we did. I was talking to one at an equipment show and I was saying that parking was really tight; I would have a hard time going home. "No problem," she said and picked up my truck and put it in the driveway.
"If you had a larger truck, I wouldn't be able to do that."
First time I had a woman comment on the size of my truck. Given the size of her arms, I'm not arguing.
Post by kozikowski » Fri Feb 15, 2013 8:36 pm
This is where the poster pops in to tell us what most of their work is so we can get closer.
Post by kozikowski » Fri Feb 15, 2013 8:40 pm
The crunching newspaper test can be valuable just by listening. Compare the sound of a known good microphone to a mystery one. If you have good headphones or killer sound system, the differences will be clear.
And if I left that out, how are you listening to all this sound work? Speaker or headphone model numbers?
