Hi
How to separate voice and music instrument sound from one file on Mac Platform
thanks
Mehran Muslimi
Saperate voice and Music instument
willssmith
Re: Saperate voice and Music instument
Often that cannot be done, but see here: http://manual.audacityteam.org/o/man/tu ... ation.html
willssmith
Thanks
Regards
mehran
Regards
mehran
