The second idea as I can most sensibly envisage it only saves and retains projects that are open when Audacity is quit. This might be one project, or several projects. It's nothing to do with the last project, because if you File > Close on the last project and agree not to save, it's deleted. If you keep adding new projects without closing old ones then quit, you will find more and more project windows opening on each launch of Audacity, so this is the discipline on deciding what you do with that unsaved data. I found this a good feature in whatever program I found it in.steve wrote:Which would be what? 1 TB? More? Less?Gale Andrews wrote:There would be a prescribed size limit
Does this feature create an accumulation of unsaved projects, or does it only apply to the last project open? If only the last project, then how does Audacity keep a record of the last but one project so that it can be deleted? If it creates an accumulation of unsaved projects, where is the button that allows the user to clean up the mess?
Didn't Koz want something like this second feature? I thought he did.
With the first idea, like any size limit, the user decides. They could be shown the current space available on the temp directory or on all connected volumes. The people who have suggested this feature have not asked for a button to remove unwanted projects, but a project manager that can safely delete (saved projects) is something that has been asked for anyway. It could be extended to sets of unsaved changes that are envisaged here.
