I am new to this forum but haven't found a previous answer. Can I capture the audio from You Tube tutorials? There are some excellent audio and video ones (not necessarily just for Audacity) and I would love to retain the audio tracks for constant use.
Marge
You Tube audio capture
Re: You Tube audio capture
Some computers will capture anything playing and send it to Audacity. Some won't.
http://manual.audacityteam.org/o/man/tu ... puter.html
If your computer doesn't have the services or tools listed in the tutorial, then you may have one of the magic computers without all that built-in. For you it's special software -- or the jumper cables if your computer supports that. Most Windows laptops don't.
