No plug ins are showing their graphical interface
Help for Audacity on macOS.
D90
Post by D90 » Wed Feb 06, 2013 10:46 am
I am using Audacity 2.0.3 with OSX 10.6.8 on a MacBook Pro (2.53 Ghz Intel Core i5).
Even though I have ticked the 'Display effects in graphical mode' checkboxes in Preferences, none of my Waves plug-ins are showing their custom interfaces. They all appear as standard Apple dialog boxes.
This was the case for me in Audacity 1.31.1 too, whether or not I used the VST bridge. I was hoping 2.0.3 would solve it.
Please help!
Re: No plug ins are showing their graphical interface
Post by kozikowski » Wed Feb 06, 2013 4:59 pm
I think it's still true that Audacity doesn't support "foreign" graphics or control panels.
Yes, this does restrict the fancier filters and effects. Koz
D90
Post by D90 » Wed Feb 06, 2013 5:53 pm
Where do its limits lie?
I've seen screenshots of it displaying other graphical interfaces. How does it determine 'fancy'?
Also, I'm not sure why but each Waves plugin appears twice in the effects menu, one appended with (s) and one with (m). What does this mean?
Post by Gale Andrews » Wed Feb 06, 2013 6:07 pm
Audacity does not properly support Waves plug-ins. Most versions of Waves cause Audacity to freeze or crash, especially the Audio Units versions. What version of Waves do you have? Does that version of Waves display GUI in other VST hosts?
If Waves tells Audacity that it is a GUI plug-in in some non-standard way, or presents the GUI in some non-standard way, Audacity won't be able to understand it so will go back to text display.
D90 wrote:I'm not sure why but each Waves plugin appears twice in the effects menu, one appended with (s) and one with (m). What does this mean?
Mono and stereo? Have you read the Waves documentation?
D90
Post by D90 » Wed Feb 06, 2013 6:34 pm
Version 8.
They work in Garage Band ok, with their custom interfaces (and only one menu item per plugin).
I've got them to sort of work in Audacity, just without the interface which limits their functionality somewhat, but they don't cause it to crash.
I'd use Garage Band but it doesn't handle 48khz. :(
Post by Gale Andrews » Wed Feb 06, 2013 9:52 pm
Thanks for the details of Waves VST.
I added the details here http://wiki.audacityteam.org/wiki/VST_P ... n_problems .
