Hi,
How do I do the upgrade?
Do I have to un -install 2.02 first?
Please tell me how do do this correctly.
thx,
Lou
Upgrading from 2.02 to 2.03
guitarist321
- Quality Assurance
Re: Upgrading from 2.02 to 2.03
So have you now got a Mac computer and you are asking about OS X?
If you are on a Mac, drag the folder 2.0.2 is in to Trash, then install 2.0.3 thus - where it says "Installation instructions (.dmg files)":
http://audacityteam.org/download/mac .
if you are asking about Windows, please see here http://manual.audacityteam.org/o/man/fa ... s.html#exe .
