Hey,steve wrote:auzer666, please get out of your mind that what you really want to do is simple - it's not. The Windows sound system is a basic in/out affair, and that is fine for what it is designed for. Skype works, Audacity works, and your voice changer program works. They are not designed to all work together.
Going back to the original question:Gale Andrews wrote:I'm not quite following either.
"Can I use Audacity to record my mic and stereomix at the same time, putting my voice from the mic into it's own channel, and putting the stereo mix in a separete channel, so that I can go back and edit them individually?"
This is not a question about Audacity, this is a question about routing sound signals and as I wrote previously, the Windows sound system probably can't do this without a lot of help.
The approach that I would take is not to use Stereo Mix at all, but to run all of the audio that I want to record through a mixing desk. Then I can pan each audio source left/right as required.
If auzer666 has a really fast i5 computer (with hardware virtualization), then he can probably do what he wants by running Linux as the host system, with Jack audio system, and running the voice changing software in a virtual machine under Windows, and then using "Jack Control" to route all of the audio signals as required *** but this is not simple ***
Thanks for all your replies, and I really don't wanna keep bothering you about this. So, can you(or anyone) just answer one last thing for me...the questions about MP3s, which are in the thread right above steve's last post.
After that, I guess I'll be done because I really don't wanna keep bugging you guys about this.
Thanks.
