I wanna record calls made with Skype. I want my voice to be on one channel, and the other person's voice/any other sound to be on the other channel. And I'd like to record in WAV, 16-bit, 44.1k.Gale Andrews wrote:I'm not quite following either.steve wrote:"Stereo Mix" is "stereo" (not surprisingly), so if you are playing stereo audio and recording stereo mix, then it will record on both channels.
If you are recording with stereo mix and the sound that is playing is panned all the way over to one side, then you can record that in one channel, so what you need to do is to have your microphone connected to a stereo input and have that panned all the way over to one side, and your other sound panned all the way over to the other side, then you will get your voice in one channel and the other sound in the other channel.
Are we talking about recording computer playback and mic simultaneously by playing the mic through the speakers then recording stereo mix? If so and you mean a single input stereo jack, that needs a balance control on the mic input which a lot of machines don't have these days.
Or do you mean a recording interface with separate Left and Right, mic into one input and cable from audio out into the other input, recording from the interface?
And I wanna do this without having to buy anything. Which, I don't think is unreasonable, since I can already do this with a simple Skype recorder, just not in WAV.
How can I accomplish this?
