Audacity 2.0.3 Effect Menu Item
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
M.Klimek
Post by M.Klimek » Fri Jan 25, 2013 1:20 am
Audacity 2.0.3
Effect Menu Item: Bass and Treble
I understood the Bass Boost.
How do I set the frequency of adjustment for the Bass and Treble utility?
If the Bass and Treble values were expressed in Hz, I would then understand to adjust the gain.
I'm not sure what the designer intended with this utility.
I really did like to use the Bass Boost utility.
I would usually trim the access signal with a EQ sound curve.
Re: Audacity 2.0.3 Effect Menu Item
Post by steve » Fri Jan 25, 2013 5:04 am
It's like the bass and treble controls on an amp. The frequencies are pre-set. If you want more bass, push up the bass control . If you want less bass, pull it down. Same for treble. The "Gain" control is like the "volume" control on an amp. If you need finer control than this, try the Equalization effect: http://manual.audacityteam.org/o/man/equalization.html
paisleyparker
Post by paisleyparker » Thu Feb 21, 2013 2:04 am
good day,
please, please, please,
add back Bass Boost,
Bass & Treble + Equalizer does not equal Bass Boost,
please add back Bass Boost,
I am using Bass Boost in 2.0.2 then saving project then finising in 2.0.3,
bring back Bass Boost,
thanking you in anticipation,
PP
Post by steve » Thu Feb 21, 2013 12:01 pm
paisleyparker wrote:please, please, please,
There is a Nyquist plug-in version of BassBoost available here: http://wiki.audacityteam.org/wiki/Nyqui ... Bass_Boost
Installation instructions: http://wiki.audacityteam.org/wiki/Downl ... g_Plug-ins
paisleyparker
Post by paisleyparker » Thu Feb 21, 2013 4:28 pm
THANK YOU!
So much better!
happy days are here again!
thank you,
enjoy your day,
PP
paisleyparker
Post by paisleyparker » Thu Feb 21, 2013 6:52 pm
good day,
small issue,
when using Bass Boost on a batch of several tracks,
it lengthens each track,
adding silence to shorter tracks to equal the longest,
how to fix?
I can add Bass Boost to each track individually,
thank you,
enjoy your day,
PP
Post by steve » Thu Feb 21, 2013 7:27 pm
paisleyparker wrote:I can add Bass Boost to each track individually,
Yes, that's one way to do it.
Alternatively you can apply "Edit > Clip Boundaries > Detach at Silence" (or just press Alt+Ctrl+J while everything is selected).
If you are using the same bass boost setting for a lot of music, you may be better to set up an equivalent setting in the Equalization effect.
