Would like to run TT Dynamic Range Meter with Audacity
TheKMan
Post by TheKMan » Thu Jan 24, 2013 6:45 pm
I just downloaded this meter: http://www.pleasurizemusic.com/
But I do not know how to get it to work with Audacity(or with any other player/DAW for that matter). It is useless as a standalone and works only as a plugin with a DAW.
Please Help.
Re: Would like to run TT Dynamic Range Meter with Audacity
Post by steve » Thu Jan 24, 2013 7:49 pm
It appears to be a component for Foobar2000, but on their free downloads page it says:
"This version has an expiration date set to 31 August 2011"
Post by Gale Andrews » Fri Jan 25, 2013 3:17 pm
Would any plug-in VU meter work with Audacity until it supports real-time effects? I've never found one that does.
