Which SVN "revision" is 2.0.3 release version?
Building and customizing Audacity from the source code.
Apesbrain
Post by Apesbrain » Wed Jan 23, 2013 11:54 pm
I would like to compile the new 2.0.3 release version with ASIO. Which revision number would it be (if possible to do it this way)? If not, is there another way to accomplish this? Thanks.
Re: Which SVN "revision" is 2.0.3 release version?
Post by steve » Thu Jan 24, 2013 12:00 am
If you download now you don't need to specify a revision number as the only updates since release are a couple of minor updates to the language translation files.
Post by steve » Thu Jan 24, 2013 12:02 am
See here for how to build Audacity with ASIO support: http://wiki.audacityteam.org/wiki/ASIO_Audio_Interface
Apesbrain
Post by Apesbrain » Thu Jan 24, 2013 5:09 pm
Thanks for the quick reply. I've built ASIO version using current 2.0.4 revision; I just wanted a build that did not say "alpha".
Post by steve » Thu Jan 24, 2013 5:40 pm
Apesbrain
Post by Apesbrain » Fri Jan 25, 2013 4:34 am
Thank you, that worked except the repo is located at:
http://audacity.googlecode.com/svn/audacity-src/tags/
