Hi, Can anyone suggest a better reverb plugin I could with "presest already made" like small room up to arena settings?
If so, would I just copy the .dll file and put it in the audacity plugin folder?
Thx,
Lou
Better Reverb Plugin?
guitarist321
Re: Better Reverb Plugin?
That's a feature request. Almost word for word the one that I wrote. If you need to start worrying about millisecond recursive bounce ratios, you're totally doing it wrong.
We recommend a packaged reverb program that seems to be easier to use than the GVerb one included with Audacity, and somebody will post which one it is.
waxcylinder
I've added a vote for guitarist321 to Koz' thread - see: http://forum.audacityteam.org/viewtopic ... 91#p203791
