Record in "Slow Motion"
Emerogork
Post by Emerogork » Tue Jan 15, 2013 1:59 am
I wish to record a segment played at a slower speed than the original. I have the original in Audacity and can play it in slow speed. I wish to send it to CD and play it at slow speed on any player.
Can this be done in Audacity?
Re: Record in "Slow Motion"
Post by steve » Tue Jan 15, 2013 2:35 am
Try the "Change Speed" effect (Effect menu).
Emerogork
Post by Emerogork » Tue Jan 15, 2013 3:22 am
steve wrote:Try the "Change Speed" effect (Effect menu).
Absolutely. Discovered that within seconds on posting it.
Open mouth, deep throat foot...
Thank you,...
waxcylinder
Post by waxcylinder » Tue Jan 15, 2013 2:04 pm
posting back and fessing up is useful though - at least we know that that funcionality is "discoverable" :)
