Mc OS 10.8.2 Audacity 2.0,2 i used the Dmg
hello
how may i find the Hz value on informations in the waveform [ db ]
in order to do adjust a fine setting of EQ
thanks for your time and to let me know
bonjour
existe t'il une solutions pour trouver la valeur Hz d'un son se trouvant sur un " waveform " [ Db ]
afin d'utliser tres precisemment the equalizateur .
merci pour votre temps .
hZ finding
atomottokar
Re: hZ finding
Analyze menu > Plot Spectrum
http://manual.audacityteam.org/o/man/an ... l#spectrum
atomottokar
Re: hZ finding
yes ! yes ! i found it
thanks a whole lot
thanks a whole lot
Re: hZ finding
You can pull the display sideways and get much more detailed information.
- Attachments
- Picture 3.png (69.01 KiB) Viewed 961 times
