speed change - exporting 24bit
bomber1978
Post by bomber1978 » Fri Jan 11, 2013 9:37 am
Hi guys,
I'm using Audacity 2.0 (March 2012) with Windows 7 Pro.
I'm loading in a 48000/24bit file and changing the speed, when I go to export it the WAVE selections only allow 16 bit and the FLAC selection is also 16bit.
How do I keep the speed changed file at 24bits?
Thanks
waxcylinder
Re: speed change - exporting 24bit
Post by waxcylinder » Fri Jan 11, 2013 10:18 am
In the export dialog select "other compressed files" from the dropdown and then click on the Options button
bomber1978
Post by bomber1978 » Sat Jan 12, 2013 7:37 am
Thanks heaps!
Cheers.....
