Help with recording
link28469
Help with recording
Post by link28469 » Sat Jan 05, 2013 3:04 am
So steve, I've a problem that's related to audacity. My speakers and headphones keep blowing out in the left channel, after I've played a recording of some music I've made. The original recording was clipped badly, but I used a tutorial on youtube (/watch?v=CnwH_K85KSk or /watch?v=KM5shJycg9k) to remove clipping. The RMS looks fine, but the peak is still flat-topped. So, what I am trying to figure out, is why this is damaging my speakers after playing it enough times. It happens whether I'm in audacity or not, on my PC or on my mp3 player, through speakers or headphones, and even in FLAC, WAV, M4A or MP3 formats. I don't play audio loud, either, so I'm not sure why this is happening. Did I do something wrong?
Re: Help with recording
Post by kozikowski » Sat Jan 05, 2013 3:36 am
Select a bit of the work and post it here for us to look at. Include that clipped portion
http://forum.audacityteam.org/viewtopic ... 49&t=64936
You can't actually repair clipping. That's like a bowl of different fruits with one piece missing -- and then finding software to "repair the hole."
I'll tell Steve you said hi.
link28469
Post by link28469 » Sat Jan 05, 2013 5:35 am
kozikowski wrote:Select a bit of the work and post it here for us to look at. Include that clipped portion
Okay, do you want the source, or the edited version? And is there a format preference, or should I give you a zip of a bit of the project? By the way, I didn't really use some software to repair clipping, I amplified the tracks -6 dB, made a copy of the tracks, went to effects => equilization, pulled down at the 80 Hz mark just slightly, then dragged from 110 hz so that there is a vertical line at 80 hz, then amplify it -.1dB. I then did the inverse in the track's copy, followed by ctrl+r. Then, on first stereo track, dragged gain down -10dB, and down -^ on the second stereo track. Then I mixed it down.
link28469
Post by link28469 » Sun Jan 06, 2013 5:05 am
Ok, koz, well it looks like I can't edit this into my previous post, but here it is. Also, I've a few questions.
From now on, should I record in 32 bit wav? Since audacity converts audio to 32 to edit it anyway, should I record in 32?, or just record in 16, have audacity convert to 32, edit, and then export back out to 16 again?
If I record 2 channels in 16 bit each, and 22khz each,will that result in a stereo 16 bit or 32 bit? And will the result be stereo 22khz, or a stereo 32 bit 44khz recording.
Also, should I find a device with AGC? I've heard that it might help, but also may reduce audio quality.
orchclassperf1-clip-edited.wav
edited file
(800.04 KiB) Downloaded 51 times
orchclassperf1-clip-source.zip
source recording
(1023.67 KiB) Downloaded 47 times
Post by kozikowski » Fri Jan 11, 2013 5:37 am
I have no explanation for you.
In your illustration, the right channel is very badly damaged, not the left. I can't pin it down to your players or sound card because you say it happens on multiple devices. Your experiences are completely opposite what I would expect from the evidence.
So that's not it. I think we're looking at a scarlet fish.
What do we know about those? Model numbers? How old are they? How did they break, that is, how do you know they're broken? What does broken sound like? How many sets of each failed?
Did they stay failed, or they only act funny on this one sound clip and then perk right up for your Electro-Trance collection.
Screen shot 2013-01-10 at 9.01.06 PM.png (14.75 KiB) Viewed 1350 times
Screen shot 2013-01-10 at 9.04.16 PM.png (5.1 KiB) Viewed 1350 times
link28469
Post by link28469 » Fri Jan 11, 2013 10:35 pm
kozikowski wrote:I have no explanation for you.
I meant to say right.
What do we know about those? Model numbers? How old are they? How did they break, that is, how do you know they're broken? What does broken sound like? How many sets of each failed?}
HP NC4400 laptop speakers, ipod earbuds, hp earbuds, sandisk sansa earbuds, and sony studio monitor headphones. One of each, four hp earbuds(in other words, everything I tested) It seems to only happen after listening to the recording for a while (source or edited), regardless of whether it's on my pc or not. Theey blow out when I play this music. Basically, the right starts to sound crackly, and gradually gets worse.
kozikowski wrote:Did they stay failed, or they only act funny on this one sound clip and then perk right up for your Electro-Trance collection.
They stayed blown
I want to know if the edited file looks like it could cause damage like that.
link28469
Post by link28469 » Sat Mar 16, 2013 7:58 am
Can I please get an answer to this? I am still trying to figure this out, and my new headphones just died the same way.
Post by steve » Sat Mar 16, 2013 11:00 am
link28469 wrote:HP NC4400 laptop speakers, ipod earbuds, hp earbuds, sandisk sansa earbuds, and sony studio monitor headphones. One of each, four hp earbuds(in other words, everything I tested) It seems to only happen after listening to the recording for a while (source or edited), regardless of whether it's on my pc or not.
As koz says, the symptoms do not make sense.
Playing clipped audio is not good for speakers, headphones or ears due to the excessive high frequency content, but it is unlikely to do real damage if played at low volume.
Certain hardware faults can put a DC voltage onto the output and this can burn out speakers and headphones even if used at moderate or low volume. However you say that the problem is not isolated to your PC or any other piece of equipment and it is extremely unlikely that the same problem would be present on multiple devices.
Is there a common piece of equipment? For example, are you playing via an amplifier?
link28469
Post by link28469 » Thu Mar 21, 2013 5:32 am
No, interestingly, there isn't. For a while, I thought it was related to my SD Card that I play music off of, but it happened elsewhere, and I'm not sure if an SD Card could cause such problems, anyway. I know the audio is no longer clipped, but I just thought that maybe the audio could still do damage because it is still flat-topped. I am also unsure of what is happening. I wonder, do these hardware faults sometimes only occur with certain audio? It could be a coincidence on two separate devices... It's just so strange.
