Exporting as mp3
guitarist321
Exporting as mp3
Post by guitarist321 » Fri Jan 04, 2013 3:21 am
Hi,
Just downloaded 2.02 and dowloaded the lame encoder. When I export the file it says to save as a wav file. how do I get lame to convert it to an mp3 to hear back on my real player?
Re: Exporting as mp3
Post by kozikowski » Fri Jan 04, 2013 3:24 am
When you Export, there should be a Format selector. See pix.
Screen shot 2013-01-03 at 7.19.41 PM.png (108.31 KiB) Viewed 413 times
guitarist321
Post by guitarist321 » Fri Jan 04, 2013 4:46 am
Thanks, Got it!
