Gale Andrews wrote:Robert J. H. wrote:[...]the main problem is that Audacity can't be controlled from within an external program. The enabling of global keystrokes would solve a lot of issues connected to transcription and other tasks that involve remote playback and recording.
I vaguely seem to remember that global shortcuts were already proposed elsewhere but cast in the wind due to platform dependent issues, I don't know if this subject is pursuit any longer.
Have you had your vote counted yet for "global shortcuts"?
No, I've not voted yet.
Gale Andrews wrote:Robert J. H. wrote:Imagine that we had a "Writing mode". It's essentially a playback mode where the cursor is placed in a label track. The writing position would follow the audio timeline . As soon as you have entered one or more words the text is put in where the typing of the phrase has begun. It is clear that the normal shortcuts are disabled in this mode and replaced by special ones that let you jump back and forward, stop the playback and so on.
Jump back and forwards where/by how much?
Since one wants to rehear certain parts, the jump should be some seconds. I have 10 seconds for long jumps in my preferences. However, since new hotkeys are needed anyway, one could assign << 1 min to F4, 25 s to F5, 10 s to F6, whereas F7 to F9 have the mirrored values in the forward direction. The left and right arrows are of course also still available. Furthermore, the number keys (with a modifier) could be used to jump at 10% . . . 90% of the audio.
Gale Andrews wrote:How does this differ from arrowing down to the label track so you can then type in the label track without using CTRL + B first?
I am not working very much with labels, so it may well be that I am mistaken.
Maybe the procedure you are describing above can be used similarly. However, my entries always seem to start at 00:00:00 during playback. I should really take a look at the manual and study the label features...
The actual difference is that you are continuously entering text which is automatically inserted at the current playback position. If one has entered a couple of words, these would afterwards snap to a regular (distance 2 s or so) or accurate label position. The program must provide a semi-intelligent mechanism to re-arrange the words if necessary and move them from one label container to the next. Since one can jump back, there should also be some kind of "punching in" or overwrite mode or just a second line/entry at the position that is already occupied - maybe the best solution.
Gale Andrews wrote:Robert J. H. wrote: This functionality goes hand in hand with an improved Label editor since the phrases have to be moved easily. For example, if you open the label editor, you are placed in the label list. with up and down you could select the label and wwith left and right (shift for longer moves)you'd move them in the timeline while the you hear at the same time the audio that lies at the current position. That seems to me more intuitive than only changing the position with a direct entry in the time box.
OK that sounds like another feature request. However if you are moving labels don't you need to move them very accurately, not just in gradations of a few seconds?
Well, the start and end time boxes are still there. For the purpose of a transcription, it should be enough to move the labels 0.1 s and 1.0 s (left/right arrow keys with and without shift). If you're handicaped, it is so or so a hard job to place the labels accurately in the current appearance of the editor. At the moment, the label list can be left with the arrow keys, this would of course fall away (and be replaced with the Tab key, as it is the case in almost all dialog boxes).
Labels seem to be a permanently and broadly discussed subject, as some recent feature requests show.
It wasn't my intention to bring them in this discussion too but they seem to loom up evweywhere.
Wish you a happy New Year!
