I have a DELL Inspiron 1525 running vista, so I have no Settings in the start menu.
went to contro; panel, Do not have Sounds and Audio Devices.
How can I config laptop?
Configuring My laptop
Re: Configuring My laptop
Can you plug headphones into your computer and listen to anything? YouTube, Windows Media Music, keyboard sounds, anything? It's possible but highly unlikely that your computer doesn't have a soundcard. That can happen in a home-built computer with a custom motherboard.
ragnar.jensen
The Inspiron 1525 has a SigmaTel sound system on the motherboard.
Go to DELL's support and make sure you have the latest drivers for it.
http://www.dell.com/support/drivers/us/ ... piron-1525
Ragnar
Ragnar
