Merci de noter que la plupart des membres de l'assistance d'Audacity ne parlent qu'anglais. Par conséquent, nous ne pouvons garantir une réponse aux questions en français.
aamateratsuu
Post
by aamateratsuu » Tue Dec 25, 2012 1:29 am
Salut tout le monde,
J'ai un problème avec audacity. Je joue avec un casque avec un micro et j'aimerais savoir comment enregistrer ma voix et le jeu en même temps.
J'arrive à enregistrer la voix mais sans le son du jeu.
Merci de votre aide
Hello everybody,
I have a problem with audacity. I play with a headset including a microphone and i would like to know how to record my voice and the sound of the game in the same time.
I can rec my voice but not the game.
Thanks for you help
- Quality Assurance
Post
by Gale Andrews » Tue Dec 25, 2012 2:55 am
aamateratsuu wrote:I have a problem with audacity. I play with a headset including a microphone and i would like to know how to record my voice and the sound of the game in the same time.
Assuming you are on Windows, unmute the mic in the playback side of the sound card then record in Audacity from stereo mix:
http://manual.audacityteam.org/o/man/tu ... ndows.html .
On Vista/Windows 7 and Windows 8, you may not be able to unmute the mic. In that case go to the "Recording" tab of "Sound" in Windows, right-click over the mic > Properties, then click the "Listen" tab. Set Listen to send the mic input to your built-in sound device. Then record from stereo mix as above.
This does not work with a USB headset. It needs a headset with pink and green leads.
