installing both versions
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
cattz
Post by cattz » Fri Oct 31, 2008 8:28 am
I have V1.2.6 installed but would like to try the beta version. Can it be installed in a different folder so as to leave the stable version as is?
waxcylinder
Re: installing both versions
Post by waxcylinder » Fri Oct 31, 2008 10:03 am
Absolutely you can - just be aware that you can't actually run both at the same time.
And more importantly be awre that you can open and edit a 1.2 project in 1.2 but not the other way around. And once a 1.2 project has beem opened/edited/saved in 1.3 then it cannot be re-opened in 1.2.
Post by kozikowski » Sun Nov 02, 2008 5:14 am
However, if you don't use Projects, like me, then the Exported WAV files open perfectly either direction.
