Recording automotive exhaust sounds?
Hi,
I am new to this forum and very new to sound recording in general. I have a fairly new Lenovo ThinkPad Edge laptop running Windows 7 Pro and a Samson Go Mic. I would like to use this with Audacity to record and edit auto exhaust sounds.
I have tried a few test recordings but it would appear that I have a lot to learn. With the Go Mic set on cardioid placed about 1 meter away from the tail pipe of the vehicle I have tried several recordings. The mic is quite sensitive and will pick up the sound of me walking to the driver's compartment and starting the engine but it clips the exhaust note. If I turn the recording volume down so there is no clipping, the exhaust note is barely audible.
Can anyone point me in the right direction as to what settings to use or things to try?
Thanks,
Robert
Thanks,
Robert
Re: Recording automotive exhaust sounds?
Turn down the recording level so that the exhaust note does not clip, then post a short sample - just a couple of seconds in WAV format will be fine. We can then take it from there, See here for how to post audio samples: http://forum.audacityteam.org/viewtopic ... 49&t=64936
Hi Steve,
Thanks for your prompt reply.
The learning curve is pretty steep for an old dog like me but I'll give it a try.
I took one of my test recordings that I had played with the recording levels on. I tried to select a few seconds of the track that had no clipping and pasted it to a second new track. I then exported that clip as a WAV file and attached it to this response. Or at least that's what I've tried to do.
Regards,
Robert
Regards,
Robert
- Attachments
- E150.wav
- (803.09 KiB) Downloaded 308 times
Well done - that worked
A slightly easier way would be to select the part that you want as a file, then use "File > Export Selection".
The recording is extremely loud !
In fact it is recorded a bit too loud and is clipped (distorted) in each place that it touches the top/bottom of the track. The recording level needs to be reduced so that the recording does not touch the top or bottom of the track.
The recording may sound very quiet on small loudspeakers if they are unable to reproduce the very low frequencies that make up most of the sound. It is almost inaudible on my laptop speakers, but is quite capable of rattling the doors and windows when played on my main sound system.
To make the recording "work" on small speakers; Make an undistorted recording - a peak level about half the track height is fine. Then use the "Amplify" effect to bring the level up to 0dB, then use the "High Pass" filter set to 100 Hz, then use the "Leveller" effect with a fairly "heavy" setting. The Leveller effect will "squash" the dynamic range, making the quieter parts louder, and will also produce some overtones of those bass notes (controlled distortion). Alternatively, get bigger speakers
And now down to actual content for a minute. Are you after real exhaust sound or Hollywood exhaust? You picked one of the "Everybody Knows" effects. "Everybody Knows" that radar has to go 'round and 'round even though radar hasn't actually done that since 1968. Newsrooms have to sound like model 47 teletype machines (1963), etc.
Car Exhaust has to sound like something from the Dust Bowl era.
Exactly correct. Most exhaust today has been carefully calculated and engineered to be inaudible. It's still violent movement of air, but some of it comes out tiny pulsing whisping sounds and a majority of it is beyond the bass pedal on pipe organs. That's why you're having such a rough time with it. All but the largest speaker systems can't reproduce it and it shares the Rock Concert problem of base notes destroying the performance.
This brings up other problems as well. Microphones can be engineered not to go there because most of the people using microphones don't care about 32-foot Diapason organ pipes, so the microphones don't work very well down there. Vocal microphones aggressively limit bass notes on purpose.
And you thought you were on a regular sound recording job.
If the engine recording is for diagnostic purposes Audacity does have a spectrogram display ...
Other free spectrograph programs are available ...
https://en.wikipedia.org/wiki/SoX
And neither display tell you what you need to know. Most exhaust is well below 100Hz, a suggestion of colour at the bottom of those displays. Koz
OK, "plot spectrum" in Audacity's "Analyze" menu, with a log(arithmic) horizontal frequency axis shows the bassy resonant notes of the exhaust (50-150Hz) ...kozikowski wrote:And neither display tell you what you need to know. Most exhaust is well below 100Hz, a suggestion of colour at the bottom of those displays. Koz
I did find a (free) real-time frequency analyser (Windows only) ... http://forum.audacityteam.org/viewtopic ... 85#p182785
Good Morning Gentlemen, and thanks again for your quick responses.
I had considered that the speakers on my laptop might not be able to reproduce the base sounds. This morning I sent the file over to my wife's computer which has a pretty good sound system, Yup It's loud alright!
I also was wondering about the fact that the wave form touched the top and bottom of the track, but it didn't show as being clipped. Now I know better.
I'm an old engine freak, and to me, the sound of a healthy engine, almost any engine, is as good as the finest of symphonies. I don't expect to get recording studio quality with the equipment I've got, but I'm hoping that I can get some realistic reproductions. I'd sure appreciate some advice on how to get the best out of what I've got.
To start with, the Go Mic is a pretty basic and inexpensive piece of equipment. No doubt I could do more with a better mic but this is at least a starting point. It is a dual pattern condenser USB using a 16 bit ADC @ 48K sampling rate. A pattern switch allows the user to select cardioid, cardioid with a 10db pad, or Omni directional. The element type is Fixed Charge electret, 10mm dia with a thickness of 4 microns cardioid and 2 microns omni. Sensitivity is -47+-2dB/Pa and SPL is 121db. Frequency response is 80Hz-18kHZ Cardioid and 20Hz-20lHz Omni.
From the spec sheet I'm thinking that perhaps I would get better results using Omni because of the better low frequency response. Then again, because exhaust sounds are pulsing perhaps Cardioid with 10db pad so I could turn my recording level up a bit.
Then there is the matter of positioning the mic. At this point I'm just experimenting with a vehicle stationary so I can place it anywhere I want, but eventually I'd like to try recording under actual driving conditions so I'll be limited to having the mic on a short boom probably within no more than a metre of the tail pipe. I don't know if the mic should be aimed directly at the pipe or off to one side. Then there is the matter of dual exhaust. I suppose the best starting point would by just a mid point between the two.
I have two engines in my boat and it would be ideal if I could record in stereo, but I understand that this takes more sophisticated equipment than I have. I'm thinking that the best I can do there would be just to have the mic mid point between the two exhaust ports and settle for that.
Once I have the raw tracks recorded so there is no clipping I'm not clear on how I can edit it for best reproduction. I don't really want to "dumb it down" so it will sound reasonably good on a lap top because I intend to burn the tracks to a CD so it can be played on a reasonably good sound system.
Your thoughts and guidance would be greatly appreciated.
This is fun!
Regards,
Robert
This is fun!
Regards,
Robert
Bad news : the real-time frequency analyser I mentioned above , only has a linear frequency scale (not logarithmic) so the low exhaust frequencies (50-150Hz) are bunched-up on the far left of the (green) display ...
