What about adding a pitch bend function, as same as fade in/out?
I mean, if you want that the pitch of the selected segment will bend X notes up/down? (like a siren sound)
So about speed bending. Many times I want to decelerate slowly the song or vice versa.
I've never found function like those!
[is it the right forum for asking that?]
pitch/speed bend
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
waxcylinder
Re: pitch/speed bend
you can do the speed bending in 1.3 by adding a Time Track and manipulating it.
Umm... what do you mean manipulate it:?: When I'm trying to add another time track,
it says that my version doesn't support multiple time tracks.
However, I didn't explain my self clearly:
Sometimes I need to slow down the end of the song/melody, without changing its pitch.
With time track enveloping I can only change both speed&pitch, not the tempo only.
Anyway, thanx about the time track! didn't know about that. Is there any other use for it?
waxcylinder
I'm no expert with this functionality - but my understanding is that you manipulate it similar to the Envelope Tool. See this page from the manual that is being developed for the 1.4 release: http://www.audacityteam.org/manual/inde ... ime_Tracks.
I seem to remember a fairly recent response from stevethefiddle about the use of Time Tracks - you might try searching the forum
This is possible using Nyquist functions, though I don't know of any plug-ins that have been written yet to do this.stein138 wrote:I mean, if you want that the pitch of the selected segment will bend X notes up/down? (like a siren sound)
Nyquist programming: http://audacityteam.org/wiki/index.php? ... ist_Prompt
