Which quality should I use?
ngr
Post by ngr » Tue Dec 18, 2012 5:36 pm
I have about 10 hrs with 20 years old interviews on tape, and now I am going to digitalize them, for broadcasting on a community radio.
I know, that I shall use wav files, but I'd appreciate good advice regarding which settings I should use when I record them.
Thanks a lot
waxcylinder
Re: Which quality should I use?
Post by waxcylinder » Tue Dec 18, 2012 5:42 pm
I would use the Audacity default 44.1 kHz (44100) Project rate and 32-bit float Sample Format - use this throughot for capture an editing.
Then when you have your finished product export to the (default )16-bit PCM stereo WAV. I use triangular dithering for the down-sampling (the "High Quality Conversion" box) - though shaped is reckoned to be pretty good too.
Such files can be burned to a music CD or played in just about any player.
Post by kozikowski » Tue Dec 18, 2012 10:44 pm
That's how I delivered the last commercial voice job. Being obsessive, I deliver in Stereo whether or not the original was a single voice track because I know that's what the client is expecting. Once you go to a Music CD, the burning software is going to make it into a stereo track anyway.
You don't actually make "Stereo." you just double up the track and ship the same thing both left and right. Call the company. They may not care. I don't always have access to the client, so I have to cover all the bases.
