Can't align label tracks with another label track
Re: Can't align label tracks with another label track
Post by Gale Andrews » Wed Dec 26, 2012 7:34 am
We can add your vote for labels snapping to each other.
gasto wrote:Another issue I have found is that the selection in an audio track(by taking advantage that in the audio track, label delimiter snaps do work) does not transfer to the desired label track(by pressing the up/down arrow keys to select the label track and pressing 'Enter')
That should not be a problem.
Please give steps 1, 2, 3... to reproduce that issue.
gasto
Post by gasto » Wed Dec 26, 2012 10:03 am
There was no answer to my question in such link.
Moving the label through the circle, will only move that label and not the connected ones.
Post by Gale Andrews » Wed Dec 26, 2012 12:52 pm
gasto wrote:There was no answer to my question in such link.
You cannot move multiple labels with the mouse yet.
Drag in the label track only (not the audio track) from the left boundary of the first label to the right boundary of the last label (the yellow vertical guides will show you where to click). Then Edit > Remove Audio > Cut. Then click in the label track where you want the left boundary of the labels to go, and Edit > Paste.
Is this a problem http://forum.audacityteam.org/viewtopic ... 06#p201306 ?
gasto
Post by gasto » Thu Dec 27, 2012 1:42 pm
OK thanks, that worked.
gasto
Post by gasto » Fri Mar 29, 2013 10:30 am
Gale Andrews wrote:
gasto wrote: Another issue I have found is that the selection in an audio track(by taking advantage that in the audio track, label delimiter snaps do work) does not transfer to the desired label track(by pressing the up/down arrow keys to select the label track and pressing 'Enter')
Post by Gale Andrews » Sat Mar 30, 2013 6:11 am
If you can use a mouse, just click in the label to select its audio and open the label for editing.
If you cannot use a mouse, DOWN arrow then TAB to the label you want. This does the same as a mouse click in the label.
gasto
Post by gasto » Wed Apr 17, 2013 7:35 am
(Edited the previous explanation).
The issue is that the label track should be affected by the selection on an audio track by pressing the down or up arrow(effectively choosing the label track) and pressing enter(to transfer the selection from the audio track to the label track).
It works with the mouse(by shift-clicking on the label track), it should work with the keyboard, but it does not.
Post by steve » Wed Apr 17, 2013 9:36 am
When focus is on the audio track (indicated by a yellow line around the track), hold down the shift key and press the down arrow.
Post by Gale Andrews » Thu Apr 18, 2013 7:32 am
gasto wrote:The issue is that the label track should be affected by the selection on an audio track by pressing the down or up arrow(effectively choosing the label track) and pressing enter(to transfer the selection from the audio track to the label track).
OK I can confirm on Windows, Mac OS X and Linux that although Return/ENTER and NUMPAD_ENTER are both supposed to toggle the focused track, from Audacity 1.3.13 onwards, Return/ENTER does not toggle Label Track selectedness unless a label is selected.
I've opened a bug report http://bugzilla.audacityteam.org/show_bug.cgi?id=636 .
If you have NUMPAD_ENTER, try that instead, or after moving focus into a label track containing at least one label, use TAB then Return or ENTER twice to toggle selectedness.
SHIFT + DOWN arrow or SHIFT + UP arrow will extend the selectedness into the label track but you still won't be able to toggle selectedness of that track with Return or ENTER unless a label is selected.
Thanks
