Normalize totally destroys audio after applying LADSPA clip
YOU GUYS DEFINITELY NEED MORE ROOM TO ALLOW PEOPLE TO TYPE THEIR ISSUES!!! YOU DON'T GIVE MUCH!!!
applying a 'normalize' after applying a 'clip fix' totally destroys the audio in Audacity!!! it make the audio sound like it is in a fish tank!!! after applying the 'clip fix' the audio is still fine, but if I apply a 'normalize' to the audio afterwards, the audio gets destroyed and sounds underwater fish tank soundy, this issue has been reproduced EVERY TIME I attempted it!!!
Re: Normalize totally destroys audio after applying LADSPA c
Is the "after" in the attached sound what you mean by "fish-tank" ?justinrpg wrote:... the audio sound like it is in a fish tank!!!
- Attachments
- white-noise before-after bubblyness.wav
- (607.22 KiB) Downloaded 55 times
not quite, but sorta...Trebor wrote:Is the "after" in the attached sound what you mean by "fish-tank" ?justinrpg wrote:... the audio sound like it is in a fish tank!!!
You have been repeatedly asked not to "shout" but you have continued to be deliberately abrasive and generally rude to the people that are trying to help you. I have received multiple complaints and you have been asked nicely many times to be more civil but you continue to ignore these requests to the point where your rudeness will no longer be tolerated. Please give other forum users the benefit of common courtesy or you will be banned.justinrpg wrote:YOU GUYS DEFINITELY NEED MORE ROOM TO ALLOW PEOPLE TO TYPE THEIR ISSUES!!! YOU DON'T GIVE MUCH!!!
Are you referring to "Clip Fix" that is shipped with Audacity or some other effect?justinrpg wrote:applying a 'normalize' after applying a 'clip fix' totally destroys the audio in Audacity!!! it make the audio sound like it is in a fish tank!!! after applying the 'clip fix' the audio is still fine, but if I apply a 'normalize' to the audio afterwards, the audio gets destroyed and sounds underwater fish tank soundy, this issue has been reproduced EVERY TIME I attempted it!!!
"Clip Fix" is not a LADSPA effect.
If you are referring to a LADSPA effect, please provide the full name of the effect and a link to where it may be obtained from.
it is 'clip fix' and I thought it was LADSPA because I never saw it until I installed LADSPA... yes, I am referring to 'clip fix' + 'normalize'
I've not been able to reproduce the problem.
Could you post a sample of the audio that you are using and provide step by step instructions to reproduce the problem. Thanks.
- Quality Assurance
Would you like to post here what the issue is?justinrpg wrote:YOU GUYS DEFINITELY NEED MORE ROOM TO ALLOW PEOPLE TO TYPE THEIR ISSUES!!! YOU DON'T GIVE MUCH!!!
http://forum.audacityteam.org/posting.p ... =post&f=32
I don't understand what you are talking about.
- Quality Assurance
Are you deamplifying the audio before applying Clip Fix? That is the correct procedure but using too low a threshold in Clip Fix will harm the sound more than "fixing" it. You'll then hear the damage when you normalize or amplify to a listenable level.justinrpg wrote:it is 'clip fix' and I thought it was LADSPA because I never saw it until I installed LADSPA... yes, I am referring to 'clip fix' + 'normalize'
As a general comment, if you have complained about something and we've replied, please tell us if what we suggested solved the issue or not. We want to know in either case. If it helped, other users can then adopt the same suggestion if they have the same issue.
I found out that is is only doing that with long audio... like a 3+ minute song... I tested it on 5 seconds of music and it didn't do that... threshold of clip was set at default (95) followed by a 'normalize' at 0 db.. all I did was 'clip fix' and 'normalize' and that issue arised... but doesn't arise on 5 seconds of audio...
sorry for the delayed response, I got busy...
- Quality Assurance
If you did not deamplify the audio before using Clip Fix, the audio will clip more after using Clip Fix because it is trying to recreate the peaks that were lopped off by the excessive volume.justinrpg wrote:I found out that is is only doing that with long audio... like a 3+ minute song... I tested it on 5 seconds of music and it didn't do that... threshold of clip was set at default (95) followed by a 'normalize' at 0 db.. all I did was 'clip fix' and 'normalize' and that issue arised... but doesn't arise on 5 seconds of audio...
Is there any chance you could post a sample file on the web somewhere that demonstrates the issue? You can use
http://www.yousendit.com
http://www.sendspace.com
http://minus.com/
Dropbox or any service like that. We are not likely to get to the bottom of it unless we can see the same problem you do.
Also please tell us if you had the "Remove DC offset" and "Normalize independently" boxes ticked in Normalize.
