Mp3's created in Audacity create "Error" message when WMP sy
justinrpg
Banned
Post by justinrpg » Thu Dec 06, 2012 12:18 pm
didn't have enough room to tell the problem
I am having ISSUES with syncing mp3s created in Audacity to portable devices in Windows Media Player!!! it just generates "Error" message!!! with no additional information attached to the error message!!!
the mp3s that were created in Audacity that cause this issue are mp3s that a custom nyquist plug-in was used on the audio!!!
I do have lame for Audacity
Moderator note: Justin you have already been warned about SHOUTING and over-use of exclamation marks!!!!!!!! - please cease and desist and just write normally please, otherwise you are likely to get banned.
Re: Mp3's created in Audacity create "Error" message when WM
Post by Gale Andrews » Fri Dec 07, 2012 4:36 am
justinrpg wrote: I am having ISSUES with syncing mp3s created in Audacity to portable devices in Windows Media Player!!! it just generates "Error" message!!! with no additional information attached to the error message!!!
Are other files from the same drive failing to sync to the portable device?
justinrpg wrote:the mp3s that were created in Audacity that cause this issue are mp3s
The exact file names of the exported MP3's?
The project rate of the exported MP3's?
The bit rate of the exported MP3's (check at File > Export then click "Options...")?
The name of the "custom nyquist plug-in? Who customised it?
