Where is the Genre Listing Located?
Hi, I'm trying to do a small edit to how the genre list (for tagging the metadeta of a file) is saved. I've added custom genres and tried to find the file where they're stored in through the console, but I'm not coming up with anything. Where exactly is the genre list saved?
- Quality Assurance
Re: Where is the Genre Listing Located?
What change exactly do you want to make?
When you save a custom genre list you can find it at genres.txt in the Audacity folder for application data .
If you want to modify the list so that when you reset it, it defaults to something of your own choosing, see src/Tags.cpp in the source code. Changing that requires rebuilding Audacity.
If you save a metadata template you can see where it is saved.
If you save metadata in an Audacity project, the metadata is stored in the project file.
