Refresh selection during region label adjustment
This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the Adding Feature forum.
Technical support is available via the Help forum.
pshute
Post by pshute » Fri Nov 30, 2012 8:03 pm
If I click in an existing region label's text to go into edit mode, it creates a selection. If I leave it in edit mode while I reposition or resize the label, after the adjustment the selection is updated to match.
Would it be better if the selection was updated during the adjustment?
Use case: I'm adjusting region labels to closely match the extent of features visible on a spectrogram. Because they may be several centimetres above the bottom of the spectrogram, I have to line up the extents of the region by eye, then let go of the mouse button and see how well I've done, then readjust if necessary. The attached example is just before letting go of the button.
Re: Refresh selection during region label adjustment
Post by Gale Andrews » Sat Dec 01, 2012 6:06 am
Wiki Feature Requests has
Moving a label draws original and current edge(s) in waveform without having to select the label
I think if that was generalised more "moving or resizing a label draws original and current edge(s) in waveform" (less the "without having to select the label" ), that would cover your case?
pshute
Post by pshute » Sat Dec 01, 2012 12:35 pm
Gale Andrews wrote:Wiki Feature Requests has
I looked there, didn't see that one. Yes, I'd vote for that one, so long as the edges are drawn and updated during the move, whether it's selected or not.
Post by Gale Andrews » Sun Dec 02, 2012 7:02 am
OK I've made a note to add that vote as you describe (so no need to move it into Pending Feature Requests).
