Editing only one channel
ngr
Post by ngr » Tue Nov 27, 2012 11:14 pm
I am editing a stereo recording, but how to I reduce the level on only one channel?
Thanks
Re: Editing only one channel
Post by steve » Tue Nov 27, 2012 11:39 pm
The easiest way is to use the track "Pan" slider.
The slider will not visibly change the waveform, but you will be able to see the effect in the playback meter (and hear the effect clearly if you are using headphones).
By the way, it is possible to click on the left or right edge of the meter toolbar and resize/reposition it to make it wider - making it bigger makes it a lot easier to read (see here: http://manual.audacityteam.org/o/man/me ... l#resizing)
ngr
Post by ngr » Wed Nov 28, 2012 12:50 am
What is the pan slider?
Post by kozikowski » Wed Nov 28, 2012 1:31 am
One of the two sliders to the left of your blue waves. One is loudness and the other is pan (back and forth).
Post by steve » Wed Nov 28, 2012 1:49 am
See here for the parts of the Track Control Panel http://manual.audacityteam.org/o/man/au ... html#panel
ngr
Post by ngr » Wed Nov 28, 2012 2:11 am
IC. So if I move the slider all the way to th left, any change/editing will apply only to the right channel, right?
ngr
Post by ngr » Wed Nov 28, 2012 2:13 am
No, that's not the case.
So what do I do, if I want to reduce the level in the right channel?
Post by steve » Wed Nov 28, 2012 3:24 am
ngr wrote:IC. So if I move the slider all the way to th left, any change/editing will apply only to the right channel, right?
No, I mean if you move the Pan slider to the left the right channel will be quieter. That is what you asked for. Do you mean something different?
ngr wrote:So what do I do, if I want to reduce the level in the right channel?
Do you mean that you want to reduce the level in the right channel for just part of the track?
ngr
Post by ngr » Wed Nov 28, 2012 2:23 pm
Exactly.
waxcylinder
Post by waxcylinder » Wed Nov 28, 2012 5:38 pm
In which case you can split the stereo track -
1) Click in the track name in the Track control panel and select Split Stereo Track
2) operate on either track independently
3) rejoin the tracks by clicking in the trackname in the TCP of the top track of the two and select Make Stereo Track
Hey presto ... ( it's only easy when you know how :) )
