1.3.5 beta snapping on cuts
MRDR
Post by MRDR » Mon Oct 27, 2008 6:34 pm
Hey, has anyone figured out a way to get rid of the snaps created when cutting/silencing?
It happens when you silence, at the beginning and end of the silence, and at the beginning and end of any section of audio. This gets really annoying when joining cuts/compiling lots of channels..
It sucks... I try to zoom in and silence a snap... that only creates 2 more (1 at the beginning and 1 a the end of silence) lol
Solutions? or is this most likely my sound card :|
Re: 1.3.5 beta snapping on cuts
Post by steve » Mon Oct 27, 2008 6:54 pm
Not quite sure what you mean. Do you mean that you are getting a "click"sound at the edit point? If so, try and make your edit points happen at "zero crossing points"
MRDR
Post by MRDR » Mon Oct 27, 2008 7:18 pm
Yeah, at the end point and start point. I am fairly new to this, and I had no Idea about editing at a zero crossing points.
I'll try it out and see if that's my problem.
Thanks!!! You probably just helped me out big time :)
edit - Yep, that was my problem, Thanks a bunch!
