Problems with Realtek hda
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
rockstar1o9
Re: Problems with Realtek hda
Post by rockstar1o9 » Mon Nov 24, 2008 1:16 am
To fix it in Vista (or Windows Server 2008), you have to enable Stereo Mix under Recording Devices.
Right-click over the speaker icon in the System Tray > Recording Devices.
Or click Start > Control Panel > Hardware and Sound > Sound (if you're using "Classic View" there's a direct link to "Sound" in the Control Panel), then click on the "Recording" tab.
You'll probably see Line In, Mic, Realtek Digital Input and maybe a few others depending on your setup. Right-click somewhere in the list and check the box next to "Show Disabled Devices".
A grey-ed out Stereo Mix will show up. Click on it and select properties and under Device Usage change the drop-down to "Use This Device (enable)".
Go into Audacity, go to Edit -> Preferences and change the Recording Device to "MME: Stereo Mix (Realtek High Def.)" and hit OK.
Audacity should now be working on Vista + Realtek HDA!
***If it doesn't work, check your Realtek Tray and Volume Tray panels and make sure Stereo Mix isn't muted or something.
