Zoom @ selected, not @ cursor?
tommyd
Post by tommyd » Thu Nov 22, 2012 11:35 am
Hi,
I have a quick question about zooming in on the waveform display:
Is it possible to make the zoom "focus" the currently selected point in the waveform, rather than the position of the mouse cursor?
Thank you,
td
(Audacity v2.0.02 on XP SP2, installed from .exe)
Re: Zoom @ selected, not @ cursor?
Post by steve » Thu Nov 22, 2012 2:54 pm
I'm not sure what you mean by "the currently selected point in the waveform, rather than the position of the mouse cursor".
You can zoom to the current selection with Ctrl+E
