Hey folks==
So I got a new macbook pro with leopard 10.5.5 and had apple migrate my files from the previous MBP using tiger. My audacity files will play fine but when I try to export them to mp3 audacity can't find the lame file I had previously downloaded.
Should I download some new version of lame? Where would I find that? Any known issues with exporting audacity files using leopard?
Thanks.
Lame version for leopard? Exporting mp3 from osx10.5.5?
Re: Lame version for leopard? Exporting mp3 from osx10.5.5?
Instructions for setting up LAME: http://audacityteam.org/wiki/index.php? ... stallation
