Sound Finder was introduced as an experiment and at the time it was thought that it would eventually be merged with Silence Finder.
The code base of Sound Finder is essentially the same (ancient code) as Silence Finder with some extra bits bolted on.
Both plug-ins fall short of current standards.
Whether we retain two effects, or consolidate the features into one, there needs to be decisions made about what features are needed, and if we retain two effects, which features go in which effect.
To get the ball rolling, here is a very simple (too simple) plug-in that can mark either sounds or silences.
This version clearly does not have enough features to replace the current versions, but I am putting it forward as a possible basis for a new version.
The questions are:
- What features need to be added to make this a viable, modern replacement for Sound / Silence finder?
- Can these features be incorporated into one plug-in without it becoming too complicated for ordinary users?
