Custom Keyboard Shortcut Not Saving
Lawrie
Post by Lawrie » Wed Nov 21, 2012 12:53 pm
I thought I'd report that after upgrading my Windows XP partition to Windows 8 and installing Audacity 2.02, I seem to have the same problem as I did in Linux. See this post:
http://forum.audacityteam.org/viewtopic ... 48&t=68434
Re: Custom Keyboard Shortcut Not Saving
Post by steve » Wed Nov 21, 2012 5:48 pm
Lawrie
Post by Lawrie » Wed Nov 21, 2012 9:29 pm
I believe it's the same as 594. In other words (and per my post in Linux), customer key entries don't stick.
Post by steve » Wed Nov 21, 2012 10:42 pm
As I'm not a C++ programmer I can't do anything about the bug but hopefully it will be fixed soon.
Does the workaround that you used on Linux work?
Lawrie
Post by Lawrie » Wed Nov 21, 2012 10:44 pm
steve wrote:As I'm not a C++ programmer I can't do anything about the bug but hopefully it will be fixed soon.
Yep, the workaround in Linux worked fine. Going to do the same thing in Windows.
Post by steve » Wed Nov 21, 2012 10:51 pm
Bug 594 is already marked as platform independent (not just one operating system) and it is marked "P2" (the second highest priority) so it has to be fixed before the next Audacity release.
Post by Gale Andrews » Thu Nov 22, 2012 7:32 am
steve wrote:Bug 594 is already marked as platform independent (not just one operating system) and it is marked "P2" (the second highest priority) so it has to be fixed before the next Audacity release.
That was only true when we had the previous Beta / "stable" distinction. P2 is now up to the Release Manager to decide whether to fix it or not at release time.
All releases are now "pseudo-stable" where a new release cannot be significantly worse than 2.0.0.
So any bug that would have been P2 when we had the Beta / "stable" distinction would most likely be a P1 now. And since several P2's were demoted to get 2.0.0 out, they possibly ought to be (at least) P2 now.
See http://wiki.audacityteam.org/wiki/Bug_L ... y_Priority .
