1.3.6 (beta) Broken in Vista
dattrax
Post by dattrax » Sun Oct 26, 2008 2:07 pm
1.3.6 (beta) problems
On Vista SP1 when going to preferences options audacity crashes with a 'Audacity, the Free, Cross-Platform Sound Editor has stopped working' Seems to be OK on XP with SP3.
The download link supplied to ffmpeg in
http://lrn.1986.li/other/gsoc/ffmpegcit ... encies.exe
is missing or broken.
I believe I can work around the Vista problem by directly editing the .cfg file, but has someone got the ffmpeg download?
Cheers
Jim
Re: 1.3.6 (beta) Broken in Vista
Post by steve » Mon Oct 27, 2008 3:04 pm
dattrax wrote:has someone got the ffmpeg download?
I've not tried it yet, but try this page: http://audacityteam.org/wiki/index.php?title=FFmpeg
Copius
Post by Copius » Tue Oct 28, 2008 12:46 am
dattrax wrote:1.3.6 (beta) problems
Jim
I'm seeing exactly the same behaviour. Vista SP1 Audacity 1.3.6 As soon as I try and access Preferences = Crash!
dattrax
Post by dattrax » Tue Oct 28, 2008 1:00 pm
I have a workaround.
add
[FFmpeg]
enabled=1
to the .cfg file
The download link for the ffmpeg looks like it has now been restored
raymer
Post by raymer » Mon Dec 22, 2008 10:44 am
dattrax wrote:I have a workaround.
add
[FFmpeg]
enabled=1
to the .cfg file
I want to try the WMA direct import feature using ffmpeg. I have the same issue - trying to access preferences causes Audacity to crash (on Vista SP1). I tried the workaround above and it seems to enable ffmpeg but instead of prompting me for the path it tells me to go to preferences (grrr!)
Looking at the syntax of the config file I tried
[FFmpeg]
enabled=1
FFmpegLibPath=C:Program Filesffmpeg-binarybinavformat.dll
and
[FFmpeg]
enabled=1
The second one seems close, no prompt at startup, but when I try to import an WMA file it doesn't work and gives me two prompts 1 - Audacity tried to use the libraries and couldn't find them, 2. Audacity couldn't import the file
Sorry I paraphrased the error msgs. I have to run now. Spent too much time on this already but I would love to get it working. Any help?
Thanks,
Ray
