AutoHotKey to add a label (Windows)
Audio software developers forum.
Edgar
Forum Crew
Re: AutoHotKey to add a label (Windows)
Post by Edgar » Wed Nov 14, 2012 8:10 pm
I am the "college" to which Steve refers above. I use two other scripting facilities on Windows and find I also must insert "Wait X" statements ranging from X equal to .01 to .2 seconds. I have spent a lot of time working on the C++ code for Audacity and I think I understand what is happening. Audacity spends a lot of time "spinning" in a specific drawing loop after every event the app receives (there are other "spin" loops as well in the language translation code for instance). The amount of time spent spinning varies based on a number of factors. I brought this to the attention of the Developers but it is deep in the fundamental code and not of immediate interest to any Dev. Anyway, the best solution is to be generous with timing statements in your macros!
Post by steve » Wed Nov 14, 2012 9:12 pm
Gale Andrews wrote:@Steve, are you saying you can reproduce the problem on Linux
Yes,on Linux, If I get Autokeys to type:
Code: Select all
Ctrl b test <enter>
with no pausing and I'm zoomed in close, the screen scrolls horizontally as described by pshute.
I can't produce the problem by speed typing with hands.
