I've changed my mind about this.steve wrote:"Mid-Fade Cut/Boost" will not work with "Log" ....
"Mid-Fade Cut/Boost" can work with logarithmic and exponential fades. I'll try it out in the next version.
Does this merely mean that those not using presets could have more choice of Fade Types?steve wrote: "Mid-Fade Cut/Boost" can work with logarithmic and exponential fades. I'll try it out in the next version.
Code: Select all
Use Fade Preset ornUse Controls below"
Code: Select all
;control preset "Use Preset [PR] or Controls" choice "Use Controls,PR:Fade In (Linear),PR:Fade Out (Linear),Use Controls" 1
The log/exp code is not yet complete, so my comment was more of an update on progress and a correction to something that I wrote previously rather than an announcement.Gale Andrews wrote:Does this merely mean that those not using presets could have more choice of Fade Types?
I've used the terms "Fade In" and "Fade Out" when referring to "fading in from silence" and "fading out to silence".Gale Andrews wrote:I still think it should be called Fade In or Out, not Up or Down
I thought the same. In version 24 (not complete yet) it is "High point gain" and "Low point gain". I'll leave it like that for now and it can be updated if anyone thinks of something better.Gale Andrews wrote:If we don't specify which slider is which, it might make more problems than it's worth trying to give the sliders an understandable label.
It is very unlikely that any of the users will exclusively use one preset - at the very least I'd expect both "In" and "Out" presets to be used. My comment about "fade outs" being more common than "fade ins" was specifically about fading out songs / pieces of music, but there are many other uses of fades. Over all fade uses, fade ins are probably just as common as fade outs.Gale Andrews wrote:A default is usually the most common case, not the least common.
That depends on what you mean by "log". By "Exponential" I meant as in exponential growth/decay (like the Envelope tool).Gale Andrews wrote:Are you sure we don't need a pair of log presets?
This effect does not have EQ. I was referring to "Pro Fade Out", which has a first order Butterworth filter with a corner frequency that slides down from half the sample rate to 100 Hz.Gale Andrews wrote:With your new -1/+1 slider, what is the EQ power setting?
Which is why we will still need to have "Pro Fade Out" in addition to this tweakable fade (as it does "stuff" that the tweakable fade doesn't - and no other fade that we currently have does either).steve wrote:This effect does not have EQ. I was referring to "Pro Fade Out", which has a first order Butterworth filter with a corner frequency that slides down from half the sample rate to 100 Hz.Gale Andrews wrote:With your new -1/+1 slider, what is the EQ power setting?
What an interesting idea Robert. I agree that it is probably some way off in the future, but a very interesting idea.Robert J. H. wrote:The idea is the following:
Your plug-in doesn't apply the fades, instead it serves as a setup or editor for the fades for a session.
+1steve wrote:What an interesting idea Robert....Robert J. H. wrote:The idea is the following:
A bit more progress on the log/exponential fades.Gale Andrews wrote:Does this merely mean that those not using presets could have more choice of Fade Types?steve wrote:"Mid-Fade Cut/Boost" can work with logarithmic and exponential fades. I'll try it out in the next version.
I've copied this post to a new topic so that it doesn't get lost: http://forum.audacityteam.org/viewtopic ... 74#p192974Robert J. H. wrote:A little side remark.
It is maybe only a possibility for the distant future but nevertheless worth a short reflection.
The main feature requested on the wiki is:Gale Andrews wrote:Or, that you want a model where all dropdown choices permit access to all the sliders, without one-click presets (so more like the version prior to "#23")?
