Operating System: Windows 7 (32 bit)
Thank you for making Audacity available to the world as you do. As a developer myself, it is obvious that a lot of hard work has gone into creating and evolving this extremely useful tool.
What I am Trying To Do
If I close Audacity on the main screen and restart it, it appears in exactly the same position and dimensions as when I closed it. However when I do this on the secondary screen and the secondary screen is placed below the primary screen, only the title bar re-appears until I click it. I expected Audacity to regain it's height and width as it was when I closed it or at least reappear in it's default height and width.
How to Reproduce the Problem
I have two monitors setup one above the other (not side by side). The top monitor is my primary desktop. The two displays have been setup correctly in the Windows display settings so that I can move things up from the bottom monitor and have it appear on the top monitor.
- Place Audacity on the bottom (secondary) screen
- Close Audacity by clicking on the X located in the upper right corner
- Start Audacity again
It looks like this is a result of the way the height of the window is being saved. I suspect the source code may either not be calculating coordinates in the right order or it may not allowing for negative coordinates which happens when the secondary monitor is either below or to the left of the primary one. To ensure that coordinates are within the display area, I recommend that the saved coordinates be compared to the total display area. If they are outside that range, then they would need to be re-calculated to be inside the area or default coordinates should be used. This includes the left, top, height and width (not bottom and left) to ensure that Audacity doesn't appear horizontally or vertically collapsed.
I've experienced this issue in my own development which is why I am familiar with the issue. Let me now if you have any questions.
Additional Information
- I do not need to record anything.
- There is no error message that appears.
Best regards,
Michael Milette
