Uses For Audacity
Audio software developers forum.
adnmance
Uses For Audacity
Post by adnmance » Mon Oct 22, 2012 6:45 am
Can Audacity be used for signal processing, or only for simple recording/mixing/mastering? Is there a plugin that permits Audacity to record streaming audio/signals ?
Re: Uses For Audacity
Post by steve » Mon Oct 22, 2012 8:39 am
adnmance wrote:Can Audacity be used for signal processing
Yes, but not "real-time" processing. The signal needs to be recorded or imported, then processed.
adnmance wrote:Is there a plugin that permits Audacity to record streaming audio/signals ?
No. Audacity records whatever the sound system sends to it. It is the job of the sound system to send the signal that is to be recorded.
On Linux and most older Windows computers the sound system can be set up to send streaming audio as the recording input signal (often called "Stereo Mix" on Windows machines). On some newer Windows computers and on Mac OS X it may be necessary to use third party software to route streaming audio to the recording input. One example of a Windows application for doing this is "Total Recorder", and for Mac OS X there is "Sound Flower" (there are others).
See here for more information: http://manual.audacityteam.org/man/Tuto ... e_computer
adnmance
Post by adnmance » Mon Oct 22, 2012 9:55 am
thankyou very much for your answers. i don't seem to have configurable windows options to record streaming input, other than from the mic. thanks though i'll have to read more about audacities features to see how it can be of use to me.
