remove all silence
justinrpg
Banned
remove all silence
Post by justinrpg » Sun Oct 14, 2012 5:53 pm
is there an Audacity plug-in or way to remove all silence at any part of an audio???
justinrpg
Banned
Re: remove all silence
Post by justinrpg » Sun Oct 14, 2012 6:06 pm
nevermind I see it now... I knew I saw 'Truncate Silence' somewhere before, it was missing from Audacity but now it is there... it wasn't the first time I opened Audacity
