Problem Loading Custom Keyboard Shortcuts
Please state:
Lawrie
Re: Problem Loading Custom Keyboard Shortcuts
Post by Lawrie » Sat Mar 09, 2013 10:26 am
Gale Andrews wrote:A patch has been committed which should fix this, so this fix should be in 2.0.4 Release.
Thanks Gale. Looking forward to it.
Lawrie
(SOLVED)Re: Problem Loading Custom Keyboard Shortcuts
Post by Lawrie » Tue Sep 10, 2013 7:53 pm
Just reporting that the keyboard shortcut issue is solved in 2.0.4 for Windows. I've given up on Linux altogether as an operating system (even though I really like it).
Thanks Audacity Team :)
Post by Gale Andrews » Wed Sep 11, 2013 2:23 am
Thanks Lawrie - it should be solved for Mac and Linux, too (if you use 2.0.4).
