need help using audacity
sulfeericwale
hello i recently got this and i am using windows 7. i cannot save my audio. actualy there is alot it isnt allowing me to do but thats all i need to do right now.
Re: need help using audacity
Split to new topic as your question does not help the other Audacity user.
See here for help with how to post a question: http://forum.audacityteam.org/viewtopic ... 49&t=63799
We can't help you unless we have a clear picture of what the problem is.
sulfeericwale
all i am trying to do is save my audio i just recorded using my turtle beach headset. i am using windows 7. version 2.0.0 of audacity. i recorded it and i can cut out parts i dont need but when i got to save it almost everything under file is unusable. same for edit and the other icons on the top. i ust need to know why it wont let me save my comentary. im a little on edge because i had to record it 5 times and things have just gone from bad to worse so a quick solution would be nice.
thankyou
thankyou
- Quality Assurance
Make sure you have pressed the yellow Stop button - see http://manual.audacityteam.org/o/man/fa ... tml#grayed .
I assume that you are saving the file, if so, after you save it, you need to export your tracks to a wav or MP3 or one of the other formats. try that, hope it helps, Marty
